Displays the configuration of the Web server target.
| target | Specifies an alpha numeric string that identifies the configured target. |
N/A.
Use this command to display information about the configuration of the Web server target. If a target is not specified, all configured targets are displayed.
The following command displays the configuration of the configured targets:
show xml-notification configuration
The following is sample output from this command:
Target Name : sqa **Server URL : http://10.255.129.22:8080/xos/webservice (VR-Mgmt) Server User Name : admin Enabled : yes Queue Size : 100 Connection Status : connected Configured Modules : ems,idmgr Target Name : epi **Server URL : http://10.255.59.6:8080/xos/webservice (VR-Finance) Server User Name : admin Enabled : yes Queue Size : 100 Connection Status : connected Configured Modules : ems Target Name : test3 **Server URL : https://10.120.91.64:8443/xos/webservice (VR-Mgmt) Server User Name : admin Enabled : yes Queue Size : 100 Connection Status : not connected Configured Modules : ems Target Name : testingcorrect **Server URL : http://10.66.254.211:8080/xos/webservice (VR-Mgmt) Server User Name : admin Enabled : no Queue Size : 100 Connection Status : not connected Configured Modules : idMgr,ems
When a particular VR has been specified in the configuration process, that VR is displayed next to the URL. When no VR is specified since the parameter is optional, the default VR supplied by the XML client is VR-Mgmt. When you are using a version released before the virtual router option was added, VR-Mgmt is displayed.
This command was first available in ExtremeXOS 12.4.
